1998 Dodge Dakota Brake light & ABS light stay on &
1998 DODGE DAKOTA
91,000 MILES • 6 CYL • 2WD • AUTOMATIC
MJWILLERT2
  • 19 POSTS
When I started my truck today my brake light & ABS light on my dash stayed on. Also my speedometer was not working at all from 0 to 20 miles per hour (mph). It appears to be reading properly from 20 mph and faster. The transmission seems to be shifting properly at all speeds. I was told by a service station that it might be a speed sensor. Is this a speed sensor problem and if so, which speed sensor is it?
Aug 13, 2009 at 3:10 PM
  • CERTIFIED EXPERT
  • 110,175 POSTS
There is one vss. It could cause the problem with the speedo, but I question it has anything to do with the ABS.
What I recommend is taking the truck to a nationally recognized parts store and have them scan the computer for codes. If the light is on, there will be a trouble code stored in the computer. Then, you'll know where the problem is coming from. NOTE: Most of these parts stores will scan the computer for free, so there is no money out of pocket to identify the problem.
Let me know what you find
Aug 13, 2009 at 10:27 PM
MJWILLERT2
  • 19 POSTS
When I started my truck today my brake light & ABS light on my dash stayed on. Also my speedometer was not working at all from 0 to 20 miles per hour (mph). It appears to be reading properly from 20 mph and faster. The transmission seems to be shifting properly at all speeds. I was told by a service station that it might be a speed sensor. I drove my truck over to an auto parts store and they hooked up a scanner to the computer on my truck and found no codes, probably because the "check engine light" was not on, only the ABS & brake lights were on. I then went over to a auto repair shop and they looked for codes and they told me that the codes they found only indicate a place for them to start diagnosing the problem, that the codes do not tell them the exact problem. I do not know if I believe that or not. The shop wanted about $85 to diagnose the problem. Where should I go from here?
Aug 19, 2009 at 1:16 PM
  • CERTIFIED EXPERT
  • 110,175 POSTS
At this point, I would recommend having them check it. Without a code, anything I say will be an opinion. I still feel it has something to do with the VSS but can't guarantee it with checking it.
Aug 19, 2009 at 6:09 PM
