1998 Dodge Dakota 98 dodge dakota Rev problem.
137,000 MILES • 6 CYL • 4WD • AUTOMATIC
JCART
When in park and I barley touch the gas pedal the motor will rev to 3 grand and after about 4 seconds the motor will go back to normall. It acts like the pedal is stuck.
Nov 2, 2010 at 9:32 AM
  • 110,248 POSTS
Has the check engine light come on? Have you checked the idle air control valve, throttle position sensor, vacuum leaks...?
Nov 2, 2010 at 3:09 PM
JCART
The check engine light is on. I unpluged the throttle position sensor and it will rev up. So im sure that is good.
Nov 3, 2010 at 6:07 AM
  • 110,248 POSTS
Does it stall if you disconnect the IAC? Have you checked for vacuum leaks?
Nov 3, 2010 at 6:46 AM
JCART
No leaks that I can hear. And when I disconnect IAC there is no change.
Nov 3, 2010 at 7:00 AM
  • 110,248 POSTS
Remove the IAC and make sure it is working. It should stall the engine when disconnected.
Nov 4, 2010 at 12:03 AM
