1998 Dodge Dakota 1998 dodge dakota trans starting in 2nd
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
JAYSTEPH
So my dakota had a tranny leak from the front of the tranny, after pulling the tranny I discovered that the problem was the torque converter had broken the front cap off. I replaced the front seal and torque converter, put everything back together and took it for a test drive. When putting the truck into drive, it feels like its starting in second gear and takes for ever to get up to speed. I replaced the gov press solenoid and sensor, still have the same problem. Any ideas? I'm into the tranny for 400 already, maybe better to get a new one? Thanks for any help
Mar 20, 2010 at 7:27 AM
  • 110,248 POSTS
Has the check engine light come on? Does it shift into other gears properly?
Mar 21, 2010 at 3:44 PM
JAYSTEPH
[quote:08fe488e60="Jacobandnickolas"]Has the check engine light come on? Does it shift into other gears properly?[/quote:08fe488e60]
Yes engine light came on, read 1757 I believe, looked it up and pointed me to the gov solenoid and sensor. It does shift into other gears but not 1st. Been a little afraid to take it faster than 55.
Mar 22, 2010 at 8:51 AM
  • 110,248 POSTS
THis is a tough one because you already repaired what the computer said was bad. The only other thing I can think of is a faulty valve body or shift solenoid.
Mar 22, 2010 at 2:52 PM
JAYSTEPH
Hence my confusion. think its time for a new tranny. Thanks for the input!
Mar 23, 2010 at 6:14 AM
  • 110,248 POSTS
Is it the original transmission?
Mar 23, 2010 at 2:59 PM
JAYSTEPH
yes I believe it is. When I bought it the guy said he had it rebuilt not long before I bought it.
Mar 28, 2010 at 4:33 AM
  • 110,248 POSTS
It shouldn't need replaced then. Chances are the gov is where the problem is coming from. What I suggest it to take it to a trans shop, let them know what "You" want checked, the gov, and see what they find.
Mar 29, 2010 at 12:48 AM
