1998 Dodge Dakota
FERDJR
  • 1998 DODGE DAKOTA
Noises problem
1998 Dodge Dakota 6 cyl Four Wheel Drive Automatic
98 dodge dakota squeaking under hood when accelerating when I take foot off gas it stops I don't know if its belt or pulley just checking before I buy
Monday, December 8th, 2008 AT 8:42 AM
  • 109,885 POSTS
Hi:
If it happens when you hit the the gas, it sounds like the belt. Here is a test to try. Turn all electrical components on high, AC, fan, wipers, radio, and anything else you have. Let the truck idle inneutral or park and hit the gas quick. If the sound seems worse, it's the belt. Also, if the sound is worse in the morning, that is another time when the alt works harder to recharge the battery. There is only one problem. You have a serpintine belt on the truck. If it's in good condition, the belt tensionier most likely bad and in need of replacement.
Let me know what you find.
Monday, December 8th, 2008 AT 5:27 PM
