I have a 1997 Dodge Dakota Sport, V6, 4X4. When the outside temp falls below 32 degrees I have a problem. Engine starts fine. After 10 or 15 minutes of driving I sometimes cannot go uphill over 15 miles an hour. Downhill is worse, I leave off the gas, the RPM's fluctuate by as much as 1000, it the backfires. I have replaced the cam sensor and the air temp. sensor. If the check engine light comes on, it signifies the cam sensor. HELP!! I'm at my witts end! Do you think it could be the crank sensor or possibly the temp. sensor?
Dec 10, 2008 at 9:15 AM
