1997 Dodge Dakota Start-up and Idle Problems
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
BULLDOG1986
I have recently noticed that my Dakota will not idle after start-up. It will start and immediately die unless I give it some gas. If I keep my foot barely on the accelerator and shift it into drive and can get it moving for a fair distance it will run. Otherwise the RPMs drop and it cuts off. No problem lights are illuminated. Can you help me out? Thanks
Scott
Jan 27, 2009 at 6:22 AM
JDL
  • 16,098 POSTS
If it runs ok, off idle, but won't idle, I always think of the idle air system, might be a clogged passage or something?
You might see if there are any codes, some of the national brand autostores will check codes for free.
Jan 27, 2009 at 8:04 AM
