1997 Dodge Dakota pcm
1997 DODGE DAKOTA
96COBRACLONE
Electrical problem
1997 Dodge Dakota 4 cyl Two Wheel Drive Manual
i have a 97 2.5 dodge dakota, i just rebuilt the motor and put it in yesterday but it will not start, cranks and has fire but no fuel to the injectors. i checked the fuel pump and theres no power to it, pcm is throwin a 12 code and in the manual it say a 12 code meand power to the pcm is discontinued but i can figure out which fuses or relays feed power to the pcm
Jul 12, 2010 at 10:23 AM
  • 110,240 POSTS
That's odd because you shouldn't have spark without the PCM. Are you getting power to the fuel pump relay? Also, check all the fuses and relays in the power distribution box.
Jul 15, 2010 at 4:38 PM
