1997 Dodge Dakota no spark
138,000 MILES • V8 • 2WD • MANUAL
POSSOM
i have no spark coming out of the coil i changed the pick up coil and still no spark
Sep 25, 2008 at 12:57 PM
  • 110,246 POSTS
Have you followed the wires back from the coil? Chrysler is known for having wire splices that corrode and loose contact. They actually place them in the center of wiring harnesses. You should try following the supply lines backwards to figure out where the power is being lost. If you already changed the pick-up coil, it truly sounds like a corrosion problem.
Does the vehicle try to start?
Sep 30, 2008 at 6:49 AM
