1997 Dodge Dakota High Idle speed
NYQUIST247
  • 1997 DODGE DAKOTA
Engine Performance problem
1997 Dodge Dakota 6 cyl Two Wheel Drive Manual 106K miles
My Dakota has 106K miles, and is a 5-speed manual. For some reason the truck idles at about 2100 now instead of its usual 800/900, what is my problem
Wednesday, April 16th, 2008 AT 5:45 PM
BMRFIXIT
  • 19,053 POSTS
Do u have check engine light on and if so get the code s
it sounds as you have a vacuum leak
check under hood for vacuum leaks and check idle control valve
you can try the key trick
get the codes and let me know
Wednesday, April 16th, 2008 AT 8:31 PM
