1997 Dodge Dakota distributor
1997 DODGE DAKOTA
SHEAPENCE@YAHOO.COM
Engine Mechanical problem
1997 Dodge Dakota V8 Automatic 140000 miles
I had a mobil machanic do a oil pump and when lifting engine he broke distributor and when he took it out he put a new one in and tucks wont start. How do i fix this
Sep 25, 2010 at 11:06 AM
WRENCHTECH
  • CERTIFIED EXPERT
  • 20,761 POSTS
It sounds like you need to find a different mechanic.
One that first doesn't break things when he does a job and second, knows how to install a distributor or whatever else he broke.
I can give you the series of tests to isolate the cause of the no start but if the same guy is performing the tests, then it would probably be futile.
Sep 25, 2010 at 11:22 AM
