1997 Dodge Dakota clunking noise from front end
252,735 MILES • 6 CYL • 4WD • AUTOMATIC
AKNIGHT1001
i have a clunking noise that seems to be coming from the front end but im not possitive. it happened after going off road. i have no front axle movement but the gear reduction works fine. the noise gets really bad when i turn either direction. i have to keep it in 4hi otherwise the clunking noise gets really bad and sounds like something is about to fall off the truck. the wheel bearing are basically brand new heavy duty ones, the tie rod ends seem to have no play in them, the cv axle has a small cut in the boot but there is no play in it. im kinda stumped on this one any ideas or suggestions will be greatly appreciated. thanks 11/15/09
Nov 15, 2009 at 2:20 AM
  • 110,246 POSTS
Have you checked ball joints? Also, if you turn the steering wheel (in 2wd) and drive in a circle, do you hear a clicking sound?
Nov 17, 2009 at 10:45 AM
