HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Dakota
Climate Control
Air Conditioner
Compressor
SPONSORED LINKS
1997 Dodge Dakota
SEVEERNAYR
MEMBER
1997 DODGE DAKOTA
V8
2WD
AUTOMATIC
160,000 MILES
Whu would my compressor be cycleing on and off when I run the heater
Friday, October 2nd, 2009 AT 6:12 PM
OBXAUTOMEDIC
MECHANIC
On a lot of newer vehicle 96 and up the a/c compressor cycles with heater on.
SPONSORED LINKS
Friday, October 2nd, 2009 AT 6:57 PM
SEVEERNAYR
MEMBER
Mine never has till now
Sunday, October 4th, 2009 AT 8:27 AM
OBXAUTOMEDIC
MECHANIC
Sorry for delay in getting back to you.
Have you had any problem with your A/C?
How often does it cycle?
If it cycles frequently then you may not have noticed it before and you may be low on freon.
If I am not mistaken, with a full charge on A/C and heat on the A/C usually cycles about every 10 - 15 minutes or so.
Tuesday, October 6th, 2009 AT 12:05 PM
Please
login
or
register
to post a reply.
Related Air Conditioner Compressor Content
Compression Test Tool
I Need To Purchase A Compression Test Instrument. I Read Many Comments About Various Testers And There Seems A Common Complaint About The...
Asked by
waynev
1987
DODGE DAKOTA
2001 Dodge Dakota Noise From The A/c Compressor
I Have Change The Water Pump Two Days Ago, Took It For A Spin And It Over Heated. I Change The Thermostat And The Truck Was Working Good...
Asked by
Paul Rochon
1 ANSWER
2001
DODGE DAKOTA
2000 Dodge Dakota A/c Blows Cold When First Started...
Problem First Started Last Fall About 45 Min After The Truck Had Been Driven. It Blew Cold Then Just Eventually Faded Away. The First Few...
Asked by
ryan1225
2000
DODGE DAKOTA
A/c Issues
Hi. I Just Got A 1993 Dodge Dakota Sport-3.9. A/c Is Giving Me Issues. It Kicks On, And The Compressor Works. I Have Put 32 Oz Freon Into...
Asked by
chadallen1979
3 IMAGES
1993
DODGE DAKOTA
96 Dodge Dakota Air Conditioning
When I Turn On The Air Conditioner The Compressor Engages For ~5 Seconds, Turns Off For ~20 Seconds And Turns Back On For ~5 Seconds. This...
Asked by
RCMason
1996
DODGE DAKOTA
VIEW MORE
SPONSORED LINKS
Air Conditioner Compressor Replacement
AC Compressor Replacement Video
Online car repair manuals
