transfer case service
SLIMMER455
  • 18 POSTS
what kind of fluid is used for my transfer case?can i buy it off the shelf?also if the truck is stuck in 4 wheel drive could it be the vacuum switch? thanks Mike
Oct 14, 2009 at 12:57 PM
  • 110,248 POSTS
This video shows the job being done on a similar car but the process is the same.
https://youtu.be/jywt228y8UM
The transfer case takes Automatic Transmission fluid Type 7176. That is Chrysler's specific type. As far as the 4wd, make sure the linkage didn't come loose. There is a lever that attaches with a set screw and it can come loose. If you get a different brand of ATF, other than Mopar, make sure it works with Type 7176. Let me know if you have other questions. By the way, my books says it holds 1.3 qts. Glad to help. Let us know if you have questions in the future. I've owned Dakotas since 1990. I've had a 90, 92, 93, 98, 2000, and now an 07. I still have the 93. It has 212K on it, 6cyl 5 speed and still runs great. I use it to haul and plow snow. It just won't die.
Oct 15, 2009 at 1:43 PM
