1996 Dodge Dakota spark
NOLUCK96
  • 1996 DODGE DAKOTA
Engine Mechanical problem
1996 Dodge Dakota 4 cyl Two Wheel Drive Manual
i have a 96 dakota with the 2.5 MPI and its lost spark.
it was getting a little hard to start one day so I parked it and after that it wouldnt start but it will crank over. So far I have replaced the ignition coil, pick-up coil, cap and rotor, spark plugs, crankshaft postion sensor, and still have no spark anywhere. What else do I need to check and/or replace to fix this problem. Also when I hooked it up to an OBDII tester it wouldnt link up to the truck? Any help would be appreciated. Thanks
Wednesday, July 15th, 2009 AT 8:35 PM
Check and test the ignition control module and ignition switch.
Wednesday, July 15th, 2009 AT 8:59 PM
NOLUCK96
I did check all that and I checked most if not all of the fusible links and the relays but all that tested good and still no spark or anything and now all the sudden I dont have fuel either so whats the possibilities of all that being linked to to computer?
Sunday, July 19th, 2009 AT 7:10 PM
Test/swap/replace the ASD relay and get back
Sunday, July 19th, 2009 AT 7:59 PM
