1996 Dodge Dakota radiator replacement
222,222 MILES • 6 CYL • 2WD • AUTOMATIC
JESSECASTON
while deinstalling the original radiator i dont have the toos needed to take the transmission cooling hoses off. is there anything i can use or how do i get thoose hoses off without damaging them
Feb 8, 2008 at 8:07 AM
BLACKOP555
  • 10,386 POSTS
if you have pressed in pressure fitigns then you cant remove them, if you have rubber and metal lines, you can cut off the rubber pressed part and splice in a new one wiht hose clamps, it works really nice, or if its all metal you can just cut out a chunk and replace it with a hose and hoseclamps.
Feb 8, 2008 at 9:39 AM
