1996 Dodge Dakota oil pump
127,000 MILES • 6 CYL • 2WD • AUTOMATIC
CONCORDE-ONE
Yes sir, i was wondering if the oil pump is in the engine or on the outside of the engine? if so is this something that is a easy fix or to the dreadedddd shop. By the way this is a 3.9
Thank you
Phil
Jan 16, 2008 at 10:25 AM
BMRFIXIT
  • 19,053 POSTS
[quote:211d4178c7="concorde-one"]Engine problem
1996 Dodge Dakota 6 cyl Two Wheel Drive Automatic 127000 miles
Thank you
Phil[/quote:211d4178c7]
inside oil pan
and if its 4x4 its not an E Z job
you have to remove the front diff to gain access to the oil pump or jack engine up
Jan 16, 2008 at 12:12 PM
