1996 Dodge Dakota Cold AC when Running, Warm AC when Idle
MTJR
  • 1996 DODGE DAKOTA
Air Conditioning problem
1996 Dodge Dakota Manual
I have a 96 Dodge Dakota, 2.5 L engine
My AC is Cycling. My truck blows cold air when RUNNING, but warm air when IDLE. The temperature reading from the vent at the coolest goes to 40 degrees F. However, when driving on the freeway at 60 mph the AC is at 75 degrees F.
When I put my gauge, the low side kicks in quickly to 55 psi and drops quickly to 35 psi. High side reading is 240-245 psi.
I also tried bypassing the low pressure switch and the high pressure switch but the AC Is still cycling. What is causing the cycling of this? Thanks
Thursday, November 5th, 2009 AT 8:28 PM
  • 109,885 POSTS
It's low on freon. Try recharging it and let me know if that helps.
Friday, November 6th, 2009 AT 10:46 AM
MTJR
Did that already. Nothing worked
Monday, November 9th, 2009 AT 1:21 AM
  • 109,885 POSTS
IF the system is cycling too fast, then the cycle switch may be bad. Have you checked that?
Monday, November 9th, 2009 AT 6:39 AM
MTJR
I have already checked that. I bypassed it
Tuesday, November 10th, 2009 AT 12:25 AM
