Bump when letting off of gas
132,000 MILES • 6 CYL • 4WD • AUTOMATIC
INSHOREMAC
Just wondering if you might know why I feel a light bang when I let off of the gas pedal. Seems to be coming from the rear of the truck but not sure.
Thanks for your help.
Feb 10, 2010 at 8:53 AM
  • 110,248 POSTS
Check to make sure the shackles are good and u-joints are tight and not damaged. Also, if that is good, check transmission and engine mounts.
Let me know what you find.
Feb 10, 2010 at 10:26 AM
S55580B
  • 7 POSTS
It is the slip joint at the front of the rear drive shaft that slides into the rear of the transfer case. When you brake, the body tips forward and the rear drive shaft pulls out of the transfer case slightly. When it pulls out it binds just for an instant. Coat the inside splines with never-seize. You will be pleased with the result.
Apr 23, 2018 at 2:44 PM
  • 55,676 POSTS
Yes good call. Here is a video on how to fix the problem:
https://youtu.be/p2snOCyqVMY
Great addition to this thread! Please feel free to help out whenever you are on the site. :)
Cheers, Ken
Apr 26, 2018 at 10:07 AM
