Have you checked for engine codes? You can do it at home. Here is how:
Cycle the ignition key from of to the run position 3 times. The 3rd time let it in the run position. THe engine light will begin to flash. You need to count the number of times it flashes. Each code will be a 2 digit number. The light will flash, have a slight pause, flash again, then have a longer pause. It will then continue on if there are more. The last code will be a 55 indicating it has finished.
Let me know what codes you get. Remember, you don't turn the key to the start position, only the run position while cycling.
Feb 13, 2010 at 5:38 AM
