blower motor removal?
78,000 MILES • V8 • 4WD • AUTOMATIC
RKREW
the heater motor would work on low or med. now it dont work at all. i replaced the heater control in the dash still nothing. fuses are good .
Jan 15, 2009 at 2:52 PM
  • 110,244 POSTS
Try replacing the blower motor resister. It's under the hood mounted to the firewall on the passanger side. You'll see a plug with aprox 8 wires going into it. Unplug it and remove and replace the resister. It's a cheap part (around 5 bucks) and it is most lilkely the answer to your problem.
Let me know if this helps.
NOTE: If the plug is melted, rewire it and check the motor to see how many amps it's drawing.
Positive feedback is appreciated.
Jan 15, 2009 at 3:19 PM
