1995 Dodge Dakota No Fire
170,000 MILES • V8 • 2WD • MANUAL
JRODBUSTER1
Cranks good,but no fire.changed the coil and the ECM and had no luck.Checked grounds.I'm stuck and need this truck,its been down for months and im on a fixed income and cant keep guessing.Can you help me?
Mar 30, 2010 at 12:57 AM
  • 75,988 POSTS
Did you have a check engine light come on or has flashed prior to this problem and when was your last tune-up?
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 30, 2010 at 11:39 AM
