1995 Dodge Dakota help
DANIELLEWIS198226
Electrical problem
1995 Dodge Dakota 6 cyl Two Wheel Drive Automatic
i have replaced the ecm , coil, pick up coil , rotor bug and cap, crank sensor and have check all the fuses wiring and even the asd relay even replaced the ignition switch in side the truck and still it wont start wht am i missing
Nov 21, 2009 at 12:10 PM
  • 110,251 POSTS
You have replaced just about everything. Is the problem that you are not getting spark?
Nov 21, 2009 at 2:53 PM
