1995 Dodge Dakota Engine keeps dying
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
PRDMARINEWIFE
Hi there. I have a 95 Dodge Dakota that all of a sudden just keeps dying everytime I put it in gear and give it gas. It was fine when I drove to work, then started acting crazy when I went to leave. I will start fine, but die everytime I go to take off. Any ideas? I thought maybe the fuel filter? It will be expensive though if that it is because I have to take it to a dealer to get that fixed right?
Aug 27, 2009 at 1:28 AM
  • 110,251 POSTS
Listen, I need you to check fuel pressure. You can do it youself. Here is a how to video and directions. Check the pressure and let me know what you find. As far as the fuel filter, it is along the frame on the driver's side. You would be able to replace it.
NOTE:You will need a fuel gauge to do the test. Most parts stores will lend or rent one to you.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Sep 9, 2009 at 3:24 PM
