1995 Dodge Dakota Engine Cooling
180,000 MILES • V8 • 4WD • AUTOMATIC
RAFAELC
My engine is overheating and we have replaced the water pump. We also put in new hoses, belts, and the cooling fan clutch. I got a new thermostat and I have replaced the cylinder heads and I tried to adjust the timing. My problem is that it is still overheating. I don't know what the problem is, and I want to make sure I've done everything I can before I think about getting a new engine.
Mar 30, 2008 at 12:02 PM
  • 75,988 POSTS
Try bleeding the cooling system
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks.
Mar 30, 2008 at 7:47 PM
