1995 Dodge Dakota Car cranks, but no spark
244,000 MILES • 6 CYL • 2WD • MANUAL
95DAKOTA_BENDER
so i was driving in the rain and right as i started letting go of the clutch and hitting the gas (from a stop) the car just shut off and wouldn't start back up, I've tried crank shaft sensor, new computer, checked the fuses, checked the alternator and voltage regulator.
Aug 18, 2010 at 3:18 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing-also check the ASD relay
Aug 18, 2010 at 8:25 PM
95DAKOTA_BENDER
thanks ill do that first thing in the morning, ill be replying again
Aug 19, 2010 at 4:22 AM
95DAKOTA_BENDER
so i replaced the crank sensor, asd relay fuses, and tried a new computer, and still nothing, the truck started hot wired but it was putting out 18volts, any ideas?
Aug 20, 2010 at 3:10 PM
