is there a cabin air filter and if so where is it's location?
Sep 16, 2009 at 1:33 AM
✓Experienced Mechanic
There is no cabin air filter in this car. Use 2CarPros anytime, we are here to help. Please tell a friend.
Sep 16, 2009 at 2:59 PM
JBSTUTZMAN
MEMBER
is this vehicle equipped with a cabin filter? and where is it?
Jan 30, 2019 at 4:25 AM
(Merged)
No cabin air filter on this model.
(Merged)
JBSTUTZMAN
MEMBER
when you look up under the dash to see the heater core. There is a black housing facing the passenger seat right behind the heater core. What is it. it has to do with the air flow when you set the ac on recirc.? The little door that is conected to a vacuum thing is broken. I'm not sure what the part is.
(Merged)
It sounds like the heater core housing. As far as the vacuum line that is broken, are you getting heat in the vehicle? Are you getting heat from all directions, for example, the defroster, vents, floor...?
(Merged)
JBSTUTZMAN
MEMBER
I am getting warm air. But i am getting enough cold air in at the same time that i can't warm up the cab. Does the heater core housing have a small door on that is controlled by vacuum? The bracket where the arm of the vacuum attatches to is completely snapped off. So when you slam the door shut you hear this Little door flopping.
(Merged)
It sounds like the blend air door. Try moving the door into different positions to see if you get more heat.
