1995 Dodge Dakota
BLACCK
  • 1995 DODGE DAKOTA
Engine Mechanical problem
1995 Dodge Dakota Automatic
I have a 1995 dodge dakota sport I haven't started it in 2 years so I tried to started it today the engine turned over and it started but it will not stay running
Tuesday, August 4th, 2009 AT 12:01 AM
CARADIODOC
  • 33,954 POSTS
Just go out and drive it.
After the battery went dead or was disconnected, the memory was lost in the engine computer. Until you relearn minimum throttle, the computer doesn't know when it has to be in charge of idle speed. To relearn minimum throttle, drive at highway speed, then coast for at least seven seconds without touching the brake or gas pedals. Higher than normal manifold vacuum for seven seconds is the signal for the computer to take a reading from the throttle position sensor and put it into memory. From then on, when it sees the same voltage, it knows you don't have your foot on the gas pedal.
Be thankful you don't have a Volkswagen. When this happens to those cars, you get to have the car towed to the dealership to have their procedure done before it will come out of Park or increase rpm above idle speed. A brilliant money-maker.
Caradiodoc
Saturday, August 8th, 2009 AT 12:37 AM
BLACCK
  • 7 POSTS
Yeah I would drive it but it don't stay running long enough to move right after it starts it cuts off
Saturday, August 8th, 2009 AT 1:10 PM
CARADIODOC
  • 33,954 POSTS
Does it stay running if you hold the gas pedal down a little?
Saturday, August 8th, 2009 AT 5:07 PM
