1994 Dodge Dakota Trouble codes 12 and 32
143,000 MILES • 6 CYL • 2WD • AUTOMATIC
NOSBOY
I replaced EGR valve (partially stuck open) and the idle improved substantially. I tried to erase the trouble codes by disconnecting the battery and the trouble codes would NOT ERASE.. Could you PLEASE help with telling me HOW TO erase the trouble codes??? Thanks Gary O... nosboy
Jun 4, 2009 at 7:23 AM
  • 110,248 POSTS
The code 32 was the egr and 12 just means the battery was disconnected within the last 50 cycles.
If the light doesn't reset with disconnecting the battery, you need to use a scanner to do it. If you go to a nationally recognized parts store, they will most likely do it for you for free.
Jun 5, 2009 at 4:36 PM
