1994 Dodge Dakota oil pressure
93,300 MILES • V8 • 4WD • AUTOMATIC
MANBRICH
my oil pressure guage will drop to low, and my truck will die, then i started losing performance and enginge chugged a bit then died, and as it sat broke down some antifreeze spilt on the ground
Oct 4, 2010 at 7:13 AM
JDL
  • 16,098 POSTS
Maybe a problem with the oil pump? The engine may need an overhaul? I'd use an analog gage inplace of the oil pressure sending unit, just to double check. My info says 6psi at idle, 30--80 psi @3000 rpms, warm engine.
Oct 4, 2010 at 7:42 AM
