1994 Dodge Dakota help
ALOHA123
  • 1994 DODGE DAKOTA
  • 6 CYL
  • MANUAL
  • 151,000 MILES
My truck runs for a little while then dies out and won't start. I checked the fuel lines, there's pressure.I don' know where else to look. Can you help, thank you.
Wednesday, July 21st, 2010 AT 7:51 PM
Do below and get back with some testing results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Wednesday, July 21st, 2010 AT 8:00 PM
