how do i replace the fuel pump?
CHRISMFANNON
I recently ran it out of gas and ever since it seems to have noticeably less power. I really doubt the pump needs replacing but since the only fuel filter is on the end of the pump, I need to know how to get it out. Maybe remove the bed?
Nov 27, 2007 at 12:36 PM
BLACKOP555
  • 10,386 POSTS
running pumps down that low with no gas to cool them is a sure fire way to ruin a pump, especially one over 100k miles. replace the fuel filter inline between the tank and the engine first, if nothing then drop the tank and you can choose to change the fuel pump filter or replace the pump. Here is a guide to help walk you through the repair with diagrams below to show you how on your car. I have also included a video on how to drain the gas out.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
and
https://youtu.be/Q5MH2gnyFH0
Nov 27, 2007 at 12:42 PM
JOSHGYORK
I need to change the fuel pump on my '98 dodge dakota sport and I do'nt now how.
Aug 17, 2019 at 5:38 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL:
Depressurize the fuel system.
Drain the fuel tank.
Remove the fuel tank from the vehicle.
Disconnect any lines that may remain attached to the pump.
Thoroughly clean the area around the pump so that foreign matter won't fall into the tank when the unit is removed.
Check the top of the pump for arrows or alignment marks. Check for corresponding marks on the tank itself. Alignment of the pump is important for routing of wiring and lines. Matchmark the pump and tank as reference for assembly.
If the pump is equipped with "fingers" and "finger locks", apply some lubricant to the assembly.
Remove the pump locknut. Some units are fitted with a lock tab. Pry it back while removing the locknut.
INSTALLATION:
Clean the filter at the bottom of the module.
Reverse the removal procedure.
Use a new gasket.
Align pump and tank marks to ensure correct routing of wires and lines.
If the locknut is the type without fingers and finger locks, tighten the nut to 40 ft. lbs. (54 Nm).
Thanks for using 2CarPros.com!
ROBSWEITZER
What is the best way to replace fuel pump,an do you have instructions, on how to
  • 110,246 POSTS
The pump is in the fuel tank. The easiest way to replace it that I have found is to actually remove the truck bed. There are 8 bolts that hold it on (which should come out easily) and then just disconnect the wiring to the rear tail lights and the filler tube at the fill location (3 screws I think). Have a friend help you lift it off and you have full access. Because I've done them before, it takes me about half an hour to complete. Otherwise, you will be dealing with the rusted fuel tank straps that always seem to break, trying to muscle out the tank, and then praying that the plastic tank doesn't crack when you tighten it back into place.
Let me know if you have questions.
KENMOHR
Engine Mechanical problem
1996 Dodge Dakota V8 Four Wheel Drive Automatic
I'm looking to replace the fuel pump on the above '96 Dakota. I've seen repair kits available. The question I have is my original fuel pump housing seems to be molded or compressed together. Is there a special trick or tool to seperate it in order to retrieve and replace the internal parts?
Aug 17, 2019 at 5:39 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
would be much easier and about same price just to purchase a used fuel pump assembly with warranty and replace old assembly.
SMOKEPOL;E HUNTER
I have a 1996 Dodge Dakota 3.9 with 150,000 miles.
the fuel wore out and I was able to find one at the
salvage yard. this is a walbro pump in a 22 gallon tank. the replacement pump is a 6 pin, the pump being replaced is a 4 pin. how do i fix this.
MERLIN2021
  • 17,250 POSTS
Go to the parts store and buy the right one, or if you want to gamble on a used fuel pump return to the junkie and have them pull the right part!
PORTERVILLEBAIL
fuel gage stuck on 3/4 tank on 1995 dodge dakota( replaced fuel pump& panel)
JDL
  • 16,098 POSTS
The wiring for the sending unit at the tank, take it loose, you can use different size resistor for full and empty, key on, see if gage reacts. I'll find the wiring diagram. You can get resistors at radioshack, doesn't cost much. Get a resistor close to ohms spec, if you want to test. Some people don't want no part of testing. That's up to you.
JDL
  • 16,098 POSTS
I don't know if you replaced the sending unit? With sending unit unplugged,key on, the gage should go to empty.
The wire colors for sending unit, one wire is yellow, the other wire is lite blue with black tracer. If you use resistor for full or empty, between those two terminals, key on, the gage should react.
PORTERVILLEBAIL
fuel pump and sending unit is one piece and new in tank.
PORTERVILLEBAIL
fuel pump and sending unit is one piece and new inside of the tank
JDL
  • 16,098 POSTS
Ok, I'd have to do the other testing at the connector. Some makes and models, you can replace the pump without replacing the sending unit.
CARLEY
need to replace fuel pump or just clean fuel tank out
BLACKOP555
  • 10,386 POSTS
when you replace the pump a good idea is to drop the tank. and scrub the tank out good as to prevent the new pump from being contaminated
KUSHAL
how to replace a fuel pump
Aug 17, 2019 at 5:40 AM (Merged)
  • 75,988 POSTS
Release fuel pressure, disconnect negative cable from battery-remove fuel from tank unstrap it remove fuel pump
https://images.2carpros.com/forum/automotive_pictures/12900_fuel_pressure_release_1.jpg
WVHOLLERMAN
1991 Dodge Dakota V12 All Wheel Drive Manual
i have a 91 dodge dakota 3.9 tbi. i hadan intermiten fuel problem that has become all time now. i have replaced fuel pump ,filter,regulator,hal effect,coil computer and still cant get fuel from injectors , i have went threw the wiring harness and cannot find any problems with it please help if you can
BLACKOP555
  • 10,386 POSTS
first steps first. check your fuel pressure. then from there check to see if the injectors are getting a pulse this can be accomplished with the use of a noid light
PATTY40
  • 39 POSTS
I just changed the fuel pump on my 1990 Dodge dakota 3.9 Engine.I bought a cheap one off Ebay.anyway the truck did run before I changed it out but was hard to start and stalled once in a while.when I took the old pump out it had a busted fuel line nd the pump had a rattle.so hey maybe I thought the pump is bad after all. When I attempt to crank it I spray throttle cleaner in it then it runs for a second and quits.I had put new injectors in it before u changed the pump.their isn't any fuel going to the injectors also I put 4 Gallons of gas in it .so what could it be I can hear the pump click for a second.
  • 75,988 POSTS
Disconnect the injector/s harness -hook up a noid lite to it, have helper crank engine over -is the noid lite flashing?
DOUGLASMJR
how to replace fuel pump and where is it located
  • 110,246 POSTS
Hi:
The fuel pump is in the fuel tank. From experience, the easyiest way to replace it is to remove the bed. There are 8 bolts holding it on, a couple wiring harnesses for the rear lights, and the filler tube which is attached by three screws. All you need is someone there to help you pick it up. Once it's off, you have full access to the top of the tank.
If you have any other questions, let me know.
NOTE: I recommend this way because fuel tank straps are usually rusted, and the tank is plastic and very easy to break when replacing it.
Aug 17, 2019 at 5:41 AM (Merged)
DAVISBLACK
I replaced my fuel pump it starts automatically it runs for five minutes then stalls every time can you help me?
  • 110,246 POSTS
Is the pump shutting down? If so, have you checked the fuel pump relay?
DAVISBLACK
Im getting fuel to the carb. so shouldnt that mean that the relay is working? I dont the have the tester for the relay so i havent checked for sure. Some people have told me it could be the ADS relay or the fuel pressure regulator. Does that make any sense to you?
  • 110,246 POSTS
If the ASD was bad, it wouldn't run. Also, if you still are getting fuel to the carb, then the pump is working which leaves us with spark. Does the engine start right back up? If it doesn't, will it start for a few seconds with starting fluid?
Finally, to answer your question, I did some checking and the truck is fuel injected. So, you could have a plugged fuel filter or a bad regulator that limits the fuel from getting to the injection. If you take off the air filter cover you will see the injectors. There should be a cone shaped mist of foel coming from them when the engine is running. Check to see if it stops. If it does, see if the truck will start with starting fluid and let me know what you find.
