1994 Dodge Dakota doesn't run right
RACINMOMMA1
  • 1994 DODGE DAKOTA
  • 6 CYL
  • 4WD
  • 117,000 MILES
Whe ever you rive up the engine it wants to die, or when you stop at a red light or stop sign it will die. I have put a new egr valve on it and it didn't seem to help. When I checked the codes that is what it said was wrong.
Saturday, February 7th, 2009 AT 3:42 PM
  • 109,885 POSTS
Hi:
You may have a weak fuel pump. Most parts stores will lend or rent the needed gauge and if you need directions, check out this video.
https://www.2carpros.com/dia/test_fuel_pressure.htm
Let me know what you find.
Saturday, February 7th, 2009 AT 10:41 PM
