HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Dakota
Brakes
Symptoms
Pedal Goes to the Floor
SPONSORED LINKS
1994 Dodge Dakota
ROSAFONSECA
MEMBER
1994 DODGE DAKOTA
Brakes problem
1994 Dodge Dakota 6 cyl Manual
when I hit the breaks the pedal goes all the way to the floor before it stops
Friday, February 12th, 2010 AT 5:12 PM
MECHANIC
If the brake fluid is full in the master cylender, and there are no leaks, chances are you need a new master cylender.
SPONSORED LINKS
Saturday, February 13th, 2010 AT 1:40 PM
ROSAFONSECA
MEMBER
The brake fluid in the master cylinder was almost empty. I stuck my finger in the opening and I only touched liquid at the bottom
Saturday, February 13th, 2010 AT 4:49 PM
Please
login
or
register
to post a reply.
Related Brake Pedal Goes To The Floor Content
1990 Dodge Dakota Brakes Go Completely To The Floor
All The Brake Warning Lights On Dashboard Suddenly Came On And Brakes Went Completely To The Floor While Driving One Day. There Was No...
Asked by
bambismailbox
1 ANSWER
1990
DODGE DAKOTA
GUIDE
Brake Pedal Goes to the Floor
Experiencing a brake pedal that goes to the floor can be a frightening situation, particularly when you need to stop quickly. The automotive brake system is a hydraulically...
All New Breaks, Pedal Goes To Floor
My Husband, Who Is A Retired Mechanic, Just Put All New Brakes On His Truck. He Had Me Help Him Bleed Them But They Still Go To The Floor...
Asked by
sissy74
1 ANSWER
2006
DODGE DAKOTA
1996 Dodge Dakota No Brake Pedal When Running
With The Truck Turned Off I Have A Perfect Brake Pedal But When I Start It I Loose It All I've Changed The Master Cylinder, Brake Booster...
Asked by
PVT.SMITH
1 ANSWER
1996
DODGE DAKOTA
1993 Dodge Dakota No Brakes
This Truck Is Not Used Much So Sits Around A Lot. Last Time I Moved It, It Had No Brakes. I Parked It On A Level Spot And Replaced The...
Asked by
davidlewis
1 ANSWER
1993
DODGE DAKOTA
Brakes Lose Pressure
I Have A 2005 Dodge Dakota. Sometimes The Brakes Lose Pressure And Go To The Floor. The Brakes & Calipers Were Recently Replaced. I Bled...
Asked by
JGAST71
1 ANSWER
3 IMAGES
2005
DODGE DAKOTA
VIEW MORE
SPONSORED LINKS
Steering Wheel Shaking
Brake System Warning Light
How to Fix a Brake Pull
Online car repair manuals
