1993 Starter
113,000 MILES • 6 CYL • 2WD • AUTOMATIC
NSLIPKNOT
When i go to start my truck it makes a clicking noise. If i keep turning the key on and off it eventually starts. I changed the battery and had the auto parts guy check the starter, altinator and battery and their all good. Is the problem in the stering colum or is it something else? Thanks a lot.
james
Aug 17, 2008 at 4:32 PM
  • 75,988 POSTS
Could be the ignition switch/park and neutral switch/starter relay-bad connections between the battery and starter
Aug 17, 2008 at 11:35 PM
