1993 Dodge Dakota Window won't roll down and door won't ope
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
SGSOONERS
When you roll down the driver's side window - it will only go so far and then it causes the door to pop open. The door won't open from the outside - but opens fine with the inside handle. Where do I take it for repair?
Nov 17, 2009 at 6:38 AM
  • 110,248 POSTS
Remove the inner door panel. It sounds like the linkage for the outside door handle has come off and the window is hitting it when you open it causing it to open the door.
Let me know what you find.
Nov 17, 2009 at 10:28 AM
