1993 Dodge Dakota tring to figure out what the problem is.
164,000 MILES • 6 CYL • 4WD • MANUAL
RAC34
truck is popin thorught the intake i have done a tune up cap,rotor,wires,plugs,pickup coil, coil due to it being cracked, timing chain, O2 sensors, crank position sensor oil soaked, check fuel system it is with in spec even when popin, compression test good acrossed the board all over 115, 100 is spec in book for 3.9 V6 what else could it be ?
Dec 10, 2009 at 8:42 AM
  • 110,248 POSTS
Have you checked intake vacuum to determine if there is a vacuum leak? Also, have any codes come up? Do you need directions on how to check for codes?
Dec 10, 2009 at 1:30 PM
