1993 Dodge Dakota transmissiom
HOPE NAUMAN
Transmission problem
1993 Dodge Dakota 6 cyl Four Wheel Drive Automatic
engine reves up a little more than normal before the tranny kicks into first. Jjiffy lube said internal oil pressure was a little low on last service. Do i need a band adjustment?
Apr 15, 2010 at 8:07 PM
  • 110,244 POSTS
How did they check the trans pressure? Were they servicing it (power flush)?
Apr 16, 2010 at 2:34 AM
HOPE NAUMAN
yES I BELIEVE IT WAS A POWER FLUSH.
Apr 16, 2010 at 11:40 AM
  • 110,244 POSTS
THey would be guessing. They didn't actually check pressure. They most likely made that determination based on how quickly the flush processed. I'm not saying they are wrong, but I feel it is an opinion other than a fact.
As far as a band adjustment, I don't think that is the problem. Have you tried any additives for the seals?
Apr 16, 2010 at 3:03 PM
HOPE NAUMAN
tHANKS I WILL TRY THE ADDITIVES.
Apr 17, 2010 at 6:55 AM
  • 110,244 POSTS
Let me know what you find.
Apr 18, 2010 at 7:56 AM
