1993 Dodge Dakota power problem
150,000 MILES • 6 CYL • 4WD • MANUAL
DATALORE
I have replaced my ignition coil, my cap and rotor. I can get .5 volts to the cap from the ignition coil, but can not get power past the distributor. I assume the timing chain is intact, sense the rotor spins when ignition is ingaged. What can cause this? My truck turns over but will not start.
Dec 20, 2008 at 7:20 AM
  • 110,251 POSTS
Hi:
If you are getting power to the distributor but no further, there has to be a problem with the rotor or the distributor cap itself. Make sure there are no cracks in the cap or rotor. Also, make sure the coil wire is good.
Dec 23, 2008 at 3:55 AM
