1993 Dodge Dakota OBD Port
1993 DODGE DAKOTA
MIKE08
Engine Mechanical problem
1993 Dodge Dakota V8 Two Wheel Drive Automatic 150.00 miles
hay guy's, were is the obd scan port for a 1993 dodge dakota 318 auto. we can't find it. thanks
Dec 28, 2008 at 5:35 AM
  • 110,244 POSTS
Hi:
There isn't one. You check for codes by cycling the key from off to run 3 times and leaving it on the 3rd time. The check engine light will flash X-numbers of times with a delay between numbers. You need to count the flashes to identify the code.
Let me know if this helps.
Dec 29, 2008 at 7:48 AM
MIKE08
thanks for the help . wondering if you could tell me what code 12&55 are? mike
Dec 29, 2008 at 9:17 AM
  • 110,244 POSTS
Hi:
My manual goes from code 11 to 13. Are you sure you got 12? Please double check. As far as the 55, that indicates end of fault codes sequence.
Double check the 12, and I continue looking. Also, what problem are you having with the truck? I have the same truck and at 180K I've been through most everything.
Dec 29, 2008 at 4:41 PM
MIKE08
it runs very rough when it warms up almost like it out of gas i have done complete tune up,new fuel filter,and checked fuel pump
Dec 30, 2008 at 12:08 AM
  • 110,244 POSTS
Hi:
Make sure there are no vacuum leaks (especially on the passanger side at the rear of the engine). There are several (hard plastic) hoses that run down toward the exhaust manifold that melt over the years and you can't see the problem unless you physically move them around. Also, have you had any trouble with the power brake booster? Mine went bad and I had a rough idle until the truck warmed up. The indicator was a hard pedal until the engine started (only after sitting over night). Finally, make sure the plug going to the power distribution center is tight. (it's the giagantic harnedd on the passanger side inner fender). They have been known to corrode and come loose.
Did you double check the code 12?
Dec 30, 2008 at 3:25 AM
MIKE08
i double checked the code and it is 12 ijust put a new distruber cap rotor button wires and plugs brake booster has proper operation
Dec 30, 2008 at 3:38 AM
  • 110,244 POSTS
Hi:
The only thing I could find for a code 12 is loss of battery power. From what I can tell, people are having trouble with moisture in the throttle position sensor. Check it out. I will post this problem with the director.
If this works, let me know.
Dec 30, 2008 at 4:58 PM
  • 110,244 POSTS
Hi:
I found out the a code 12 indicates the process for checking the computer has begun.
Dec 31, 2008 at 5:56 PM
