1993 Dodge Dakota no brake pressure
186,000 MILES • 6 CYL • 2WD • MANUAL
MIKELITT3810
I have great pressure when the engine is off. I have zero pressure when engine is running. I just picked this truck up and had to replace all of the steel lines due to rust. then I had this problem so I installed a new brake booster and master cylinder. rebleed the lines and still have this lack of pressure when I start the engine. The truck is equiped with Rear ABS.
Sep 19, 2008 at 3:24 PM
  • 75,988 POSTS
Bleed the master cylinder/then RWAL dual solenoid hydraulic valve then RR/LR/RF/LF wheels.
Sep 19, 2008 at 7:54 PM
