1993 Dodge Dakota fuel pump
1993 DODGE DAKOTA
CHANDI2459
Engine Mechanical problem
1993 Dodge Dakota 6 cyl
i have a 93 dakota i have replaced the fuel pump with filter and sending unit the gas gauge reads empty and the light stays on if rev it up while idoling it cuts off. while driving you have to keep foot on gas while braking or will die until warms up then its ok also my temp gauge does not work either would that have something to do with my problem. also had to replace the sensor for the oil gauge.
Sep 17, 2010 at 4:36 PM
BLUELIGHTNIN6
  • 16,542 POSTS
ECM may be faulty causing these issues, is engine light coming on?
Sep 28, 2010 at 5:39 AM
