1993 Dodge Dakota Fuel mileage
185,000 MILES • 6 CYL • 4WD • AUTOMATIC
SMILEY_1612
At the most I am only getting maybe 10 mpg on the highway and I noticed a bitter exhaust smell, like its running too rich. The air filter is clean and the oil was changed recently. I have not replaced the fuel filter yet. Several months ago I removed the cat. converter and welded in a straight pipe. Any pointers?
Feb 24, 2010 at 6:00 PM
  • 110,248 POSTS
WHen you removed the cat, did you replace the O2 sensor? That could be the entire problem.
Feb 26, 2010 at 6:05 AM
  • 110,248 POSTS
First, thanks for the positive feedback. I appreciate it.
My primary concern is the fact that there isn't an oxygen sensor since you removed the cat. As far as checking it, you have to remove it and check ohms.
Feb 27, 2010 at 3:33 PM
