HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Dakota
Interior
Instrument Cluster
Gauges
Battery
1993 Dodge Dakota
JSTNG21
MEMBER
1993 DODGE DAKOTA
V8
4WD
AUTOMATIC
235,000 MILES
Why does my battery gauge run low
Sunday, September 6th, 2009 AT 9:36 AM
CARADIODOC
MECHANIC
It reports system voltage which is obviously low. Could be a problem with the alternator, voltage regulator, or the battery itself. Any of those will eventually lead to slow cranking when trying to start the engine.
SPONSORED LINKS
Monday, September 7th, 2009 AT 1:33 AM
Please
login
or
register
to post a reply.
Related Instrument Cluster Gauge Battery Content
2000 Dodge Dakota High Voltage Gauge High
I Turn The Truck On And Everything Is Fine As I'm Driving The Check Gauges Light Comes On I Look At My Gauges And Notice That My Gauge Is...
Asked by
sweet4her2
1 ANSWER
2000
DODGE DAKOTA
1997 Dodge Dakota Gauges
I Replaced The Fuel Pump In The Tank And When I Turn The Key On The Gauges Won't Register. The Volt Gauge Is Reading Below 8 Volts With A...
Asked by
j meyers779
1997
DODGE DAKOTA
2000 Dodge Dakota Voltage Meter Goes Dead When...
Voltage Meter Works Properly When Truck Is Started Cold, But If I Turn The Truck Off After The Engine Is Warm The Voltage Meter Goes Up To...
Asked by
ThomT
2000
DODGE DAKOTA
2000 Dodge Dakota Electrical
I Have An Intermittent Charging Problem. I Drive For 20 To 30 Miles With No Issue, Then I Start To See The Battery Gauge Drop To Around...
Asked by
Reggy73
1 ANSWER
2000
DODGE DAKOTA
1993 Dodge Dakota Speedometer, Odometer, Tripmeter
Today My Speedometer Began Acting Crazy. Below 35 Mph The Needle Bounces From 0 To 125, From 35 To 45 Mph It Will Bounce Up To Around 85...
Asked by
newcreation00
1993
DODGE DAKOTA
VIEW MORE
SPONSORED LINKS
Alternator Replacement
Alternator Test
Online car repair manuals
