Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Dakota
Engine Cooling
Water Pump
Leak
1992 Dodge Dakota water pump
1992 DODGE DAKOTA
300,501 MILES • V8 • 2WD • AUTOMATIC
GRAVEDIGGER51157
MEMBER
1 POST
after my truck sits over night, it is low on antifreeze, is it possable for the water pump to leak with out the engine being on?
Apr 18, 2009 at 4:14 AM
BMRFIXIT
Experienced Mechanic
coolant pressure test is needed to reveal the leak
check under the pump on the lower radiator hose if wet suspect the water pump
Apr 18, 2009 at 6:10 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
