1992 Dodge Dakota slipage and backfire
JANWES
  • 1992 DODGE DAKOTA
  • 6 CYL
  • 248,360 MILES
The truck will backfire if you aply to much gas to the throttle at the sametime the truck will no longer engage the transmission. Could it be a vaccum problem if it is were where should I start looking?
Thank you
Sunday, January 4th, 2009 AT 1:48 PM
  • 109,951 POSTS
Hi:
When you say it will no longer engage the trans, di you mean the engine reves but the truck doesn't move? Have you done an OBD with the truck to check for codes?
Try this, with the engine and the key off, cycle the key from off to on 3 times. The 3rd time, let the key in the on position. The check engine light should begin to flash. Count the flashes for codes. Each tme there is a new number, there will be a longer delay before it begins to flash again. All codes will be 2 digits, and the final one will be 55 indicating it's done.
Let me know what you find.
Tuesday, January 6th, 2009 AT 1:46 PM
