1992 Dodge Dakota ignition cuts out, causing backfire, pingin
AE1705
  • 1992 DODGE DAKOTA
  • 6 CYL
  • 4WD
  • 123,168 MILES
I have a 1992 dakota 3.9L, 4x4
when cold very hard to start( cranks good ) When finally getting it started I must let it warm up or it cuts out like timing jumps out of wack. Can shut off and restart runs fine until it cuts out again which is happining quite often. No engine codes are coming up and have already replaced engine computer, distributor, map sensor, tps, ign. Coil, crank sensor, ign. Module. Can't think of anything else to change or look at.
Sunday, December 7th, 2008 AT 5:13 PM
  • 109,885 POSTS
Hi:
Have you checked the knock sensor? I noticed that you listed pinging as one of the problems and the knock sensor plays with the timing to eliminate the problem.
I have the same truck, so let me know what you try and I'll check it out on mine.
Monday, December 8th, 2008 AT 5:39 PM
