1992 Dodge Dakota Oil Pressure Drops When Accelerating
163,000 MILES • V8 • 4WD • AUTOMATIC
POPPA27
At idle the dash board oil pressure gauge shows normal pressure. When I accelerate the oil pressure drops to zero. If I'm driving, the oil pressure is at zero as long as I'm accelerating. When I take my foot off the gas and coast, the gauge shows normal pressure again. What is the most likely cause?
Thanks for your help.
Oct 3, 2009 at 2:13 AM
  • 75,988 POSTS
Sounds like the oil pump pressure relief valve is sticking-check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal oil pump or engine bearings
Oct 3, 2009 at 3:09 AM
