I just pressure washed the engine (318) in my '92 Dakota and when I started it there wasn't much oil pressure, barely over the low mark. The higher I rev it the higher the pressure. I shut it off and checked the oil and found small pieces of non-metallic debris on the opposite side of the dip stick. Should I immediatly change the oil? Is there anything I can do to check the oil pump?
May 26, 2008 at 11:05 AM
