We need to start back at the beginning and act like we have not done anything so that means we may do some duplication, but we need to work through this systematically.
Here is a guide that will get us started:
https://www.2carpros.com/articles/engine-backfires-while-running
Basically, backfiring through the exhaust is normally a rich fuel mixture.
Backfiring through the intake is a timing issue in most cases.
Due to the fact that you have sputtering, and backfires, it makes me think we have a fuel pressure issue.
So, let's start with checking the pressure using this guide.
I suspect we have a regulator issue that you are either having too high fuel pressure or sticking injectors.
So, if we have low pressure and a backfire in the exhaust means the injectors are most likely sticking open and preventing the pressure from building and dumping fuel into the exhaust. Or you have high pressure.
Please run through this info and let us know what you find, and we can go from there.
Thanks
SPONSORED LINKS
Monday, December 13th, 2021 AT 8:24 AM
