1992 Dodge Dakota car starts manually but not by key switch
TRACY WILLIAMS
Electrical problem
1992 Dodge Dakota 6 cyl Four Wheel Drive Automatic
switch out starter relays still same prpblem
Nov 25, 2009 at 1:25 AM
JDL
  • 16,098 POSTS
welcome, did you check the circuits at the starter relay? When you turn the key to start, can you tell if there is a load on the starter circuit. Watch the lites, they should react, when trying to crank. Voltage to the load side of relay is hot all the time. Voltage to coil side of relay goes hot with key in start position. The coil side of relay is grounded through the neutral switch, in order to energize.
Nov 25, 2009 at 1:51 AM
